Hi,
Is anyone running on 31" tyres with a 3.73 or 4.10 Diff ratio.
I'm trying to make my mind up as to which way to go. 31" tyres are plenty big enough for the type of off roading I do. In the uk we need to keep the entire tyre within the wheel arch.
It would be easier to re-gear to 3.73 as replacement front axles are readily available off XJ's and the 3.73 is within the carrier break off the, As fitted Dana44 Trac-lok rear diff
I'm fine with the present 3.07 ratio on the tarmac, But off-road in low range the gearing is much to high.
Any observations would be greatly appreciated.
Difficult to find any advice as in the States you all seem to favour 33" or 35" Tires
