Did you end up buying a new battery? I was reading another forum where the guy had the same issue and it turned out to be a collapsed cell inside the battery.According to Advance, my old battery was just under 200 cranking amps. It was a Duralast...guy said it was supposed to be around 800+? New battery is an Autocraft Gold, ~1,000 c.a.
I disconnected the new battery (overnight), reinstalled the old radio and hooked the battery back up. Put the key in, lights came on, etc. Headlights and radio worked. Turned the key....everything went off. So I think that rules out the radio/anti-theft, right?
New terminals? Like the red a black painted ones?Mystery solved.....and it was so simple, I am embarrassed to relate it. Paint on the terminals. Buddy came over, looked for about 5 minutes, asked if I had a grinder or sandpaper handy. I did not so he settled for a box cutter. Took the terminals off, scratched the paint off, reattached.....everything works like a charm.![]()
Wrong Ground(-) Turn on lights to find True Ground. False ground will continuity test positive with headlights off but will not have continuity when you pull light switch, rewire to true ground problem will go awaySomething for y'all to ponder....
Got my speakers and stereo in today so I spent the evening putting it all together. Started the Jeep a couple of times to move it to be able to open this door or that, no biggy. Tested the stereo a couple of times before shoving everything in place. Everything worked as it should (from in side the garage....didn't get to activate the Sirius.
Anyway, put it all back together again and turned the key to start the engine to maybe take a short spin....made this nasty fart sound. Sounds like there is plenty of juice but the engine didn't crank.
Any ideas what I may or may not have done??
