C
Cody k
Guest
So my 05 rme auto has a Dana 44 rear and Dana 30 front with 3.73 gears, I wanna go to 4 56 gears can I do this without changing the carrier?
OMG your Jeep would be dying on the highway with 4.56 gears, seriously. Your 42RLE has a .69 Overdrive ratio that will lower the rpms so much your engine would be lugging on the highway with 33" tires. You seriously want nothing less than 4.88 for adequate highway rpms, personally I'd go with 5.13. I just installed 5.38 gears for my 35" tires last year for my 42RLE automatic transmission and 5.38 is barely enough to keep the rpms up where they need to be. My engine was lugging badly and I never even reached 12 mpg with 35's with its 4.88 gearing. My engine and transmission immediately started running better and my mpg shot up to 14.38 after the 5.38 gearing was installed.Rocky mountain edition and I'm planning on 4in lift and 33s perfect for the tj
Gears and stuff Find a reputable shop, tell them you want 5.13's, and let them do the work. And don't let them talk you out of 5.13 and into something inadequate like 4.56.So awesome exact information I was looking for so what exactly would need to be change for this changing of gears?
Gears, bearings, seals, possibly carriers. Press, bearing pullers, dial indicator, dial calipers, inch pound torque wrench, various tools. No disrespect but, watching a couple videos does not prepare you for gear swaps. I was trained by Randy (Randys ring and pinion) and it took several differentials before I was comfortable enough to do one on my own.Lol I've seen that alot, I do manufacturing for a living and have no reason that I can't do this in not some hillyback yard mudder no offense, I would like to know what I have to change, not the whole process of doing it, that's what the internet is for and I've watched a couple videos so I'm prepared.
No, just install "thick" gears from Revolution Gear into your rear Dana 44 and you will not need a new carrier.What I want to know is am I gonna have to change my carrier or not
I explained it in my first replyWhat I want to know is am I gonna have to change my carrier or not I don't need a whole definitely I'm sorry that was not understood.
Lol I've seen that alot, I do manufacturing for a living and have no reason that I can't do this in not some hillyback yard mudder no offense, I would like to know what I have to change, not the whole process of doing it, that's what the internet is for and I've watched acouple videos so I'm prepared.
Since he has 3.73 gears installed he won't need a front carrier for 4.88 or 5.13. His front Dana 30"s carrier break is between 3.54 and 3.73.I explained it in my first reply
