You do not need to raise the body mounts, nor lower the gas tank. I was able to do it without. Using a dremel With the flex shaft extension and metal cutting wheel. You can get it at Home Depot or Lowes.
https://www.amazon.com/dp/B0000302Y8/?tag=wranglerorg-20
This method is a bit sketchy for several reasons.
1: bolt is single shear so you are counting on the strength of the bolt to not bend or snap. That's not what they are designed for.
2: most SS is about grade 2 or possibly grade 5... Don't do that, use grade 8
3: no sleeve in the frame so proper torture for that bolt could crush the frame rails (not sure what I mean? Look at how your steering box is mounted)
4: also related to no sleeve, any looseness on that bolt later on will wollow out the holes in the frame rail because it's only supposed at a very small point (the thickness of the steel on the frame side walls)
5: the tension holding that bolt in place on the frame rail is limited by the rubber bushing in the shock, no way in hell has it got the correct clamping force to stay straight in the frame long term.
6: the threaded part of the bolt is inside the shock bushing sleeve, this will alow the threads to eat into the mild steel sleeve essentially threading it and making it difficult to remove later. A few years down the road with some winter's added in for good measure, that bolt will not come out without cutting the head off and taking it through the frame with the shock.
7: did I mention how bad an idea having that bolt in single shear with no way to properly torque it is? Ok good.
8: no really, mounting a bolt that way is asking for it.
I bet if you look at the Tacoma he's talking about you will find that while a bolt does go through the frame it's got a sleeve inside so you can torque it without crushing the frame, I also bet there is a way to get correct torque on the bolt before the shock ever touches it. Even further, there may be a bracket that goes off the frame to the other side of the bolt as well to keep the tip supported.
There must have been a time
when we could have said no.
