That may be, but you don't want to run a DS that is vibrating. It will ruin your U-joints eventually...So..you may be able to mask the problem with some sort of damping material, but its not the solution you want to do.
Absolutely. The dampening material is only a band aid for sure, the root cause of the vibration needs to be stopped.
