Removing old undercoat
GeorgeSully
South Carolina
So I’ve been holding out on putting por15 on my frame for a while for one reason; there’s an aftermarket undercoating on it and Im set on doing it this today and Saturday but I’m wondering, what are some ways y’all have used to remove old paint and undercoating I was planning to just use a grinder and flap disc but any help to save some time would go a long way.
My guess is that the grinder and flap disc will work on undercoating for about 1.5 seconds each. Years ago my experience with undercoating was even when it's old and hard and crumbling, it will still plug up anything, even 60 grit sandpaper used by hand. Heck, it will even plug up a file.
I was going to suggest something to "melt" it because I just used undercoating under my front fenders because I thought it would handle rocks and stuff from the tires better than Fluid Film.I didn't undercoat any seams, let it dry, and a few days later when I Fluid Filmed the seams it melted any undercoating it touched, both rubber and asphalt undercoating.
Due to your por15 plans I'm definitely not suggesting Fluid Film, my experience with it just made me suggest something to "melt" undercoating. Maybe brake parts cleaner?
Good luck
FWIW, I put melt in quotes because I wasn't sure of a better word and wasn't trying to suggest fire. Fire would probably work as good as Fluid Film, just not a good idea.
Good luck
I see this as becoming a State Farm commercial. "And there you have it. The HOT Jeep. And State Farm covered it".
Reactions: greenliftedtj97
If A.M.Undercoat is sprayed on Grinder abrasive will clog fast This will work First spray it with Kerosene let it soak in for 1 Hr then use electric heat gun not propane to soften and use a scrapper then repeat till clean. Takes all day to do, best to do in summer when hot out. Be ready to get dirty
