Newbie looking for opinions
firedog561
Eastern Shore Of Maryland
I just bought a 05 Willys. I want to put a small lift on to run 33's. I live on flat land so it will be a beach , slight trail use. Thoughts and opinions would be appreciated.
I would go with the 2.5" OME lift or the Zone lift. Either of those are very highly rated, won't break the bank, and will give you optimal clearance for 33" tires.
Thanks, i was actually thinking of the Zone, didn't know if i should do the 3" or 4.25" combo. I'm not trying to get into a SYE and Driveshaft.
I would do the 3" in that case. That's more than enough to clear 33" tires and look great!
2" OME (which kit depends on your accessories and cargo). Can't beat the ride quality of it. Call Dirk at dpg-offroad and he'll point you in the right direction with all the parts you will need.
