Where can I get this part?
SH PARK
CA
Hi, my Zeep is 2003 TJ, I want to buy this interior part, but I can't find it in Mopar parts store and Google too.
Could you help me searching it ?
The picture is taken from the center console, just under the door.
Thanks!!
If it’s not broken and you’re looking to clean it up you might be able to paint it. There’s a lot of info on this forum about the process and colors.
Reactions: KCsTJ
That is the wiring trim panel and is only available for the drivers si
Thany you
That is the wiring trim panel and is only available for the drivers side, the passenger side did not have one.
I would try Daveys Jeeps for that.
http://www.daveysjeeps.com/
Thank you so much for the information. actually I plan to repair the passenger side. it looks so rough. otherwise, If I purchase the carpeting part, does it covers up the passenger side's wall ?
Thank you very much, I will use Color bond, Many people recommend it,
I suspected you were trying to find the part for the passenger side which is why I mentioned that it was drivers side only. This come up quite a bit with people think it's missing.
