I have a 2002 Jeep wrangler sport tj with a 4 liter 6 with a five speed trans. I can't figure out how to remove the knob. I saw some you tube videos but my must be different.
Yours may be loose enough to do that but others trying to force the knob to unscrew will likely be unsuccessful. There is a big lock-nut for the shift knob hidden underneath the plastic shift pattern that is supposed to be loosened before the knob can be unscrewed.The shift knob on my ax-5 just twists off. Lefty loosey.
Good to know...maybe I need to fix that so it doesn't rattle as much when I'm on a trail.Yours may be loose enough to do that but others trying to force the knob to unscrew will likely be unsuccessful. There is a big lock-nut for the shift knob hidden underneath the plastic shift pattern that is supposed to be loosened before the knob can be unscrewed.
Thanks, I put a pipe wrench on it. Probably hasn't been touched since 04. I wanted something a little nicer to replace it.Can't offer any advice other than righty-tighty lefty-loosey and maybe a little Kroil, Liquid Wrench, or Break-Free sprayed down inside the shift knob on the shifter threads with a little time to work.![]()
One thing I found out that I wish someone would have added to the instructions for removal is that there is a notch in the shift pattern cap at the 9 o'clock position that you insert the small screwdriver into to get under the cap and not screw it up like I did.
My shift pattern cap does not have a notch anywhere. My TJ is a 1998. The notched caps must be on some other years.One thing I found out that I wish someone would have added to the instructions for removal is that there is a notch in the shift pattern cap at the 9 o'clock position that you insert the small screwdriver into to get under the cap and not screw it up like I did.
ya I just had to destroy mine to get it off. Mine would not come out, even using the notch. The screw driver and knife I were using destroyed the outer material. When I finally got traction on the cap the screw driver literally pulled right through the center of the cap. And the cap was still seated all the way around. After that, I just went ahead and destroyed it to get it off and ordered a new oem shifter from Amazon. The new shifter looks great and if you don't put the nut on you can take it on and off with out messing with the annoying cap ever again. Just remember to put the new shifter on first (hand tight) then put the new cap on in the right orientation. Then everytime you take it off and put it back on the cap is in the right orientation.My shift pattern cap does not have a notch anywhere. My TJ is a 1998. The notched caps must be on some other years.
my 99 is 10mm X1.5Anyone happen to know the thread pattern for the AX-15 I think I remember it is 10mm x 1.5 but I’m not sure. I’ve been meaning to order a new custom knob from someone but haven’t gone out to measure it yet.
Thanks. I finally got a die and ran it over my threads. To figure it out.my 99 is 10mm X1.5
