So last weekend I bought a 97 tj from a guy that advertised it as a 2000. I knew right away that it wasn’t a 2000 after driving two hours to look at it. But I bought it anyways. It already had the 5.9 sitting in the frame. Front motor mounts and trans mount already welded in.
Now my first concern was the rear trans support. I have not seen anywhere this mount before. It has One mount on each side by the frame with one bolt through on each side. At the front drive shaft it has a loop that goes over top of the drive shaft. Has anyone ever seen this type of rear mount before and who makes it?
Next the transfer case seems to sit too high putting extreme angles on the driveshaft. No driveshaft yet still have to get one. The Jeep has either a 3 or 4” lift on it and 1.5” body lift with 33s on it.
It is a work in progress as the person I bought it from had it for 9 months sitting the way I bought it as the previous owner gave up on it. I paid more than I should have for it but the front fenders were almost perfect with just a couple of surface rust spots. I needed the fenders for my 98 to get it on the road again.
Now back to the 97. It came with brand new headers, brand new aluminum three core rad and new electric fan. It came with a brand new adjustable front trac bar, new vibrant performance cat. New three inch in and out stainless muffler but no other exhaust. The Jeep harness is there to the eco, no engine harness and no dodge harness for the engine. 2 ecms and both are for a 4.0l. It has a brand new Adams rear driveshaft with the proper yoke on the back of the transfer case but it is way too short the way the transfer case is sitting.
Well like I said it is a work in progress but I need to know about the trans mount to get that right before I proceed. Any help would be great
