K k-huevo TJ Enthusiast Supporting Member Joined Jul 16, 2018 Messages 384 Location Houston Mar 26, 2019 #21 Before After It's possible a ridge in the engine bracket can be another point of contact after a tummy tuck. For now, the ridge is out of the way. Reactions: MaloStapalo
MaloStapalo Release the Kraken Supporting Member Joined Mar 26, 2018 Messages 1,242 Location Веил, колорадо Mar 27, 2019 #22 k-huevo said: Before View attachment 84689 After View attachment 84690 It's possible a ridge in the engine bracket can be another point of contact after a tummy tuck. For now, the ridge is out of the way. Click to expand... Did you use a cut off wheel or a grinder?
OP toximus I live in my Jeep Supporting Member Joined Mar 29, 2018 Messages 7,591 Location Northern WI Mar 27, 2019 #23 MaloStapalo said: Did you use a cut off wheel or a grinder? Click to expand... Grinding disc followed up by a flap wheel. You'd be fine with just a cut off wheel too. Reactions: MaloStapalo
K k-huevo TJ Enthusiast Supporting Member Joined Jul 16, 2018 Messages 384 Location Houston Mar 27, 2019 #24 I used Dremel cutting wheels and a hand file. Reactions: MaloStapalo
