I'll start by saying I'm hoping for a thread WITH A LOT OF PICTURES. I know the frame rust issues have been beaten to death and this isn't primarily about that.
I'm curious what the average, not necessarily pristine, frames look like on all of our TJ's. What are you driving around with? This is my first TJ ever and I learned the hard way that appearances can be deceiving. While I have yet to discover any real rust on the body/tub, and the outside of the frame is mostly solid, the inside has been a whole different story.
This the latest pile I pulled out using a flex magnet. Between the shop vac and this method, I estimate I've pulled out somewhere around maybe a half gallon of flakes and chunks? A couple SCARY thick pieces - like 4 quarters stacked together thick. I have no idea where in the rail they came from/out of
The only real serious red flag on the outside is this access hole and this on the underside of the skid plate
During an inspection, I did have the shop check to see if the nutserts were broken off - they were able to loosen the bolts without spinning so that's good news. The frame was treated and coated in 2008 per the Carfax and I assume what I can see right now is that starting to come off. The rest of the frame more or less looks about this condition in the below pics.
So, what does your frame look like?!
