Best options to fix up interior?
What color paint did you use for your dash? It looks like it matches the stock pretty well.
I used rustoleum nutmeg satin... many people will criticize satin but no one knows what it looks like on the vinyl until they do it, I did it and it looks professional. Get rustoleum plastic spray paint, it matches my interior great. Don’t worry about an exact match you won’t notice if it’s a slightly different color. The nutmeg satin looks great
Thanks for the help so far everyone, it's really appreciated.
One additional question; I'm looking to add a light bar to the hood, on the existing hood latch bolts. I found the mounts for them, but I'm having a hard time finding a good light bar that doesn't cost a fortune. Any suggestions for a cheap but reliable / bright bar?
You can only pick two...... Bright, cheap, or reliable.
Reactions: Fouledplugs
Well removing the cheap, anything reliable that won't break the bank too badly? Just need it for occasional use, not looking for something to run on a regular basis.
Any ebay special, aka chinese knockoff, will do the job. What size are you looking for, 10", 20", 30" ???
Was considering something along the lines of 28” +/- a bit. The previous owner installed LED fog lights wired to a dedicated console switch. Was just going to pull power off that same circuit to turn them all on and off together. Figured it would be a relatively easy thing to do.
Would you really want to do that since you would no longer be able to use your fog lights on the main roads.
A rewire is not hard and I believe anyone who can find and sign up for this forum can do it.
For $40 this should be okay. If you jump up to the $250 range you could find a KC Hilite C series that will come with a harness.
Or just sit tight and search craigslist ebay for a used KC or Rigid industries.
https://www.amazon.com/dp/B00RWLNDRC/?tag=wranglerorg-20
I bought a set of Bartact front seat covers at Christmas time. They sell a base model set for $200 in solid black or gray. Same material as the ones posted in this thread. My Jeep isn’t a daily driver so they haven’t been used much yet but I’m happy with them. I also installed seat heaters too. Great mod.
