As part of my disassembly of all things on the interior of the Jeep prior to spraying it with bedliner, I removed the front and rear seat belts that were looking pretty worn anyways and will either be refurbished or replaced. I decided to take up the rear seat mount brackets, so that the floor could be properly sprayed and I would sand and spray paint (black) the seat mounts.
All was going well until the last damn bolt (see pic below), the head and about 1/4 of the bolt broke off, leaving the rest of the threads in the hole. The first thing I did was spray the bolt with WD-40 and then recalling my Dad and I breaking off a bolt for a valve cover many moons ago, I got out my drill and EZ Out bolt extractor thinking I was a genius, if only my Dad could see me.....
Check out the second picture of the broken extractor and the damn bolt still stubbornly in the hole. I decided to call it a day rather than do something stupid.
My plan is to go back out there with a small chisel and try to tap out the extractor pieces, then drill the bolt all the way through. Any other better suggestions are welcome.
Bob
Bob
