Looking for advice on this 2003 Sahara. 126k miles. Installed rebuilt transmission at 104k miles. All but 1,000 miles put on by the first owner who did the majority of the work. The interior is excellent. They owner is asking $14,500. I have not driven it yet, but will be meeting up with the owner on Wed. Any thoughts/comments would be appreciated. Thanks.
From listing:
Recent work includes:
- Replaced Transmission at 104k miles
- New transfer case
- New drive shaft
- New Headers, Manifold Gasket, seals, O2 sensor.
- New differential seals, fluids, pinion seal
- Front and rear thrust angle alignments and balance all tires
- New front and rear brake pads and rotors
- New Lower Ball Joints
- New Tie-rod rods and sleeve
- Track bar adjustment and tighten
- Flex joint rebuild for lift kit
- Shock remount and adjustments
- New timing cover and oil pan gaskets
- New radiator and hoses, clamps and seals
- Replace axle seals
- Recent Battery
- Rough Country 6" Long arm Lift and suspension
Features:
- Skyjacker Rock Lock Off-road Sway bar and disconnect
- Hanson front bumper
- SuperWinch EPi9.0 with remote
- New 35" Goodyear Wrangler MT/R tires (35x12.50R15LT)
- Hard top
- Bimini top (never even put on), Tonneau cover and rear seat wind catch
- Undercarriage lights
- Re-enforced front axle
- Weathertec floor covers
- OX Lockers system and custom rear differential
- Tow Hooks
- Automatic transmission, 4L inline 6 cylinder engine with AEM Brute Force intake with dry flow synthetic filter
- High-lift jack
- Rockhard rear swing-out tire carrier with (2) 5-gal gas cans and upper cooler rack
- 4.56 Differential Gearing
- Slip yoke eliminator kit
- Lower Transfer case gearing
- Custom CV rear drive shaft
- 126k miles
- Cobra CB with auxiliary speaker
- Wired for towing flat on all fours
- Blue OX tow bar connection
- Custom extended skid plate
From listing:
- New transfer case
- New drive shaft
- Recent Battery
Features:
- Hard top
- Tow Hooks
- High-lift jack
- 126k miles
