Do springs and shocks need to be matched to perform properly?
Fargo
Fargo, ND
With the release of the new Rancho 5000x shocks, we are seeing a lot of people recommending that shock for every setup. I put forth my opinion in another thread that you will have a better setup if you match the Rancho shocks to the Rancho springs or at least a spring that has a similar spring rate. It is my opinion that spring rates and shock valving work hand in hand and you will have your best results running a spring and shock combo that are designed to work together. Pairing the Rancho shocks with a spring that is much more firm than the shock was designed around will result in poor control of the suspension travel.
I have arrived at this conclusion through my own experience. About 10 years ago when I put my system together the new adjustable Rancho 9000XL was all the rage and everyone on jeepforum recommended it. Wanting the best I could afford, I paired the Rancho shocks with BDS springs. The setup in front was fine, but the rear end would dance across pot holes and the body would spring up uncontrolled after dips in the road. It seemed the shock simply could not control the suspension in the rear. Most notable was the lack of rebound dampening. Compression felt fine.
After 2 or 3 years of aggravation, I finally decided to drop the coin for some Bilstein 5160s. I decided nothing would change ride quality more than shocks and they should last 50,000 miles. So I would just spend the money and get what I determined would fit my needs the best. Sure enough, it worked. The Bilsteins handled the rear end perfectly. This was the proper solution in this scenario. (Your situation could be different)
To provide additional information: Nothing else changed. Only the shocks. I simply swapped out the Rancho 9000Xls for the Bilstein 5160s with no other changes. I think the shocks had about 25,000 miles on them. So they were not new shocks, but still had plenty of life left in them. In fact, they are in good enough condition that I just put the front Rancho shocks back on because I over extended my Bilstein and needed a quick replacement. But the spring rates in the front don't vary as much as the rear springs. So the front was never an issue. It was always the rear shocks that couldn't control the downward movement of the unsprung weight or the upward movement of the sprung weight. This makes sense when you consider the shock was designed for a spring with a rate of 150lbs and it was trying to control a spring rate of 200lbs. That is a a 35% increase in spring rate.
I suppose travel bias changed slightly. Compressed length of the shocks are nearly identical, however because the Bilstein are remote reservoir they extend an inch further in the rear and 1 1/2" further in front. So the Rancho probably had a better 50/50 up/down bias. But I don't think the extra length when extended would matter. Particularily when driving on the road. Which is where the Ranchos had the most trouble. Slow travel offroad I did not notice the issue so much. So I attribute the improvement solely to pairing the spring to a shock that was designed to handle a stiffer spring.
So that is my experience. What is the experience of others who have changed out nothing but shocks. Can a good shock work with any spring or do shocks and springs need to be paired to work together? I know what I have found out. Whats your experience.
Reactions: StG58
I ran some Bilstein 5100's with extend/collapse values fit for a 3.5" lift on a 2.5" lift and later switched to Rancho 5000X 2-3" shocks. The ride was softer with the Rancho's up to about 40mph. After that a ride quality difference was not distinguishable.
From all I have gathered on these here forums, tire pressure and shocks have the most impact on ride, not the springs.
But ride is only half of the equation. I'm not talking about a personal preference between a soft squishy ride vs a firm ride. Tires and air pressure will take care of that. I'm talking about an axle that is so uncontrolled by the shock that it slams into a pot hole and the tire bounces across the road. I'm talking about a rear end of a Jeep that is so uncontrolled by the shock that it feels like it will swing skyward until the shock reaches full extension... On flat pavement. OK, a little over exaggeration here. But you get my point. Shocks do more than provide a squishy ride.
If all the shock does is provide a squishy, ride people are wasting a lot of money on specialty shock tuning. You can read on many Jeep forums how wonderful a particular tuner is at tuning Fox shocks. Are all these people gullible fools, spending good money on a shock tune when all they need is a Rancho shock. No, they are not fools. There is a real advantage to tuning a shock. It needs to control the motion of the axle and the body while also providing a comfortable ride.
Lets take this to the extreme. If you have a shock designed for a 100lbs spring but you have a supper heavy rig so you needed springs that are rated at 400lbs, how well do you think that 100lb shock will control that 400lb spring. Once all that mass gets moving you won't even know you have a shock in there. It simply can not control the forces that are put on it. That is why the shocks must match the springs. It all works together.
Reactions: derekmac
Springs hold the vehicle up and shocks control the ride. A spring designed for the TJ will do its job at holding the Jeep up, after that, it’s a personal preference on the shock you choose for the ride you prefer.
Shocks with the exact same springs and various tire pressures will be the deciding factor.
Are you asking what springs people run with a particular shock and their experience? My springs may be either Rubicon Express or Currie, I’m not sure as I’m not the original owner. My shocks currently are Rancho RS5000’s, and the on road, they are acceptable. Simple dirt road driving with some bumps, holes and uneven surfaces, they are terrible! Feels like there is no suspension at all. I am saving for the Rancho 5000X’s.
I'm just looking to hear how changing nothing but shocks (or springs) has affected the ride AND handling of their Jeeps. Not as a single point solution but how shocks interact with the rest of the suspension as a system.
Reactions: Mikester86
I've spent time messing around with springs and spacers while keeping the same shocks. At the time, the goal was to cobble together the longest, lightest OME coil with a spacer that would get me the same amount of lift as a set of Currie 3" coils I had. I was looking for long spring travels.
I found a combination of springs and spacers that was a lighter rate than the Curries, but provided a very similar ride height. The difference was maybe a 1/4". To this day, I will tell you that the OME + spacer was a softer ride than the straight Currie 3".
However, knowing what I know now after having put together a very different suspension, the difference between the OME + spacer and the Currie 3" was so subtle that most could not have found it outside of a daily driver driven by someone focused on excruciatingly small details.
In my experience, I won't say that the differences aren't there. But they are so minor that they are not worth pursuing if the goal is to improve the ride.
I went from Skyjacker springs to a free set of BDS springs and finally to a new set of taraflex springs......nothing changed my ride until I switched to Rancho RS5000X shocks, leaving behind some old hydro shocks.
Not saying there aren't other great shocks but Springs are Springs.
That only proves that different springs can't fix bad shocks and you don't understand springs.
Yes, shocks need to be matched to the springs. However, most springs I've seen for the TJ are a similar rate, there's nothing way stiffer or softer than anything else out there.
I have a set of bilstine shocks on my miata, it rides better with 450/300lb springs than it does with the stock 162/118 because the shocks are made for the higher rate.
... However, most springs I've seen for the TJ are a similar rate, there's nothing way stiffer or softer than anything else out there.
This is a key point. For a given lift height, the available rates between our options aren't that different from each other. One of the wider ranges for a 4" is between Currie and Rubicon Express. Even then, the story is that they don't feel very different when and if the setup is otherwise comparable.
I know the the springs that I just put under the LJ only compressed about an inch from free length. The ride on the LJ seems stiff in the rear right now, but once I get a bumper on the back and some camping gear it may soften out some. If not I will look at the currie, metalcloak, and synergy springs. I just need to stay focused and get my fox shocks installed....which is new dana 44's, atlas and a tummy tuck before the shocks.
I respectfully disagree. Looking at the rear springs only, Rancho has the softest that I have come across. They are 150lbs. OME has the firmest spring for extra loads that is 250lbs. Thats a 70% increase. I would call that way stiffer. Even the more common OME LJ spring is 216lbs. Thats a 45% increase. I would call that way stiffer as well. Not to the extreme of your Miata. But certainly enough that shock valving needs to be taken into consideration.
I don't think the soft Rancho shock would work well with the stiff OME springs. They didn't work well with my BDS 200lbs springs. They didn't have enough rebound dampening. On the other hand the OME shock might control the softer Rancho springs very well, but it could also pack up if your doing some high speed washboard type stuff. It could have too much rebound dampening for the softer spring.
I think in all this we need to consider what the Jeep is being built for as well. Someone building for rock crawling might want different compression and rebound characteristics than someone like myself who is driving 1000miles to get to the trail. Although with a properly matched spring and shock combo it should perform well in both scenarios.
Thank you. That is what I was trying to get at. I think we often see to many one size fits all approach on many of the different Jeep forums. So I am just trying to get some discussion going.
Which spring was that? Didn't you just put on the JKS or am I mixing you up with someone else.
The OME 'heavy' rear spring is listed at 160lbs/in
They are one of the few that make springs in multiple rates for vehicles. Most are a generic somewhere close that works well.
Your comparisons need to be limited to coils that provide the same (or at least similar) ride heights on the Jeep we are using to make comparisons.
I happen to have a spreadsheet that calculates lift height based on sprung weight.
Here are the coils you reference with their calculated ride heights on my Jeep.
Rancho RS616 150lbs; 14.76" free; 1.54" lift
OME996 250lb; 14.57" free; 3.77" lift
OME949 216lb; 14.57" free; 3.33" lift
With the same shock installed, the Rancho coils cannot begin to be fairly compared to the OME coils with more than twice the added lift height.
