04 tj with a 4 inch lift and a 1 inch t-case drop. I have a very noticeable vibration when accelerating from 15mph and up. It shakes the dash and vibrates the steering wheel ( but a buzzing type vibration that travels through the steering column not a steering wheel shake). Its there when accelerating and gone when coasting.
Repairs done- new clutch, flywheel ( was warped a bit), pilot bearing, release bearing. Drove with front driveshaft off and still there. Removed rear driveshaft and thats good. Adjusted rear pinion angle and its near -3 degrees. Checked trans mount and it looks fine. Engine mounts look fine.
