MOTOcity Member Original poster Joined Dec 19, 2018 Messages 48 Location Salt Lake City Jul 17, 2019 #1 Is it safe to assume these wheels from a newer Jeep will fit my 97?
derekmac TJ Addict Joined Feb 10, 2016 Messages 2,576 Location NS, Canada Jul 17, 2019 #2 If they came off a JK they won't fit unless you use an adapter. The TJ is 5x4.5, and the JK is 5x5 for the bolt pattern.
MOTOcity Member Original poster Joined Dec 19, 2018 Messages 48 Location Salt Lake City Jul 17, 2019 #3 Thx. Do TJ’s of all years have same bolt pattern?
Paparock1 Angry SE Supporting Member Joined May 14, 2018 Messages 1,019 Location L.A. Lower Alabama Jul 17, 2019 #4 Yes
Steel City 06 TJ Expert Supporting Member Joined Mar 12, 2019 Messages 5,162 Location Pittsburgh, PA Jul 17, 2019 #5 Yes, all TJs and YJs use 5x4.5. You can use the JK wheels with an adapter, but they’ll stick out farther than stock wheels because the adapters also act as a spacer. Spidertrax is a name brand of adapters and spacers. Cheaper ones also exist
Unacceptable mouks TJ Enthusiast Joined May 4, 2019 Messages 250 Location Switzerland Jul 17, 2019 #6 MOTOcity said: Thx. Do TJ’s of all years have same bolt pattern? Click to expand... Yes
Steel City 06 TJ Expert Supporting Member Joined Mar 12, 2019 Messages 5,162 Location Pittsburgh, PA Jul 17, 2019 #7 If you like that style, a 16” version with 5” of backspacing was used on the TJ Rubicon wheels with a 245/75R16 tire. You can usually find them for about $70 a wheel used, or buy a new replica for $100 or so. https://www.quadratec.com/p/quadrat...p-wangler-yj-tj-cherokee-xj-grand-cherokee-zj
