Hi all! I have read countless posts on the 2.5L engine tick. My scenario seems to be a bit different from the numerous threads...details:
Symptoms:
A. When cold (a relative term, as I am in Miami FL), on startup in the morning at idle, zero ticking, sounds perfect. Temp at 100,
B. Within 60 seconds, still at idle, prominent ticking sound starts, seems to be from top of the engine. Temp rising towards normal, 130 at this point maybe...
C. Drive to the gym. 10 minutes away. Idle in parking lot, temp 200, everything humming along as normal. Zero ticking, sounds perfect
D. Return to jeep 60 minutes later, prominent ticking sound immediately on start up, at idle.
E. Drive home 10 minutes, temp back to 200, no ticking, sounds perfect.
... embarrassing as I come out of the gym people ask about the Jeep and then the TICK TICK TICK starts. I hate it!
Completed
1. New lifters, pushrods installed 3 months ago. Rocker arms tight. No difference in ticking sound behavior after the install.
2. Checked exhaust manifold - no leaks
3. Two oil changes in 3 months: with 10w50 thick oil and with 15w30 - ticking behavior the same. Fram oil filters used.
4. New power steering pump
5. New alternator
6. Replaced idler and tensioner pulley
7. Replaced the spark plugs
8. Used the extra long screwdriver-as-stethoscope strategy near the spark plugs, top of valve cover, pulleys and components. You don’t need it to amplify and can not locate as the tick resonates everywhere.
Any thoughts welcome!
This is driving me crazy, mostly as I cannot diagnose what the heck it would be... if flat spots on the cam or some internal part, it should it be present immediately on startup in the morning...Why does it sound perfect the first 15 seconds of idle and perfect after 5+ minutes to normal temp driving? Yet ticking immediately returns after letting it sit and restarting the Jeep, after it cools down ...I would assume heat expansion solving whatever it is at first but that can’t be the case because it sounds perfect when cold first thing in the morning ... I’m baffled...
Thanks for any help or insights.
Symptoms:
Completed
5. New alternator
