For the 98 wrangler, mopar discontinued the radiator for the automatic. If anyone knows where to find one that would be amazing help.
Bought mine from the dealership a couple months ago. If you call one up they should have access to the distributor stock and get one in for you. Isn’t cheap but, thing is built like a tank. Could try one of the sites like Wermopar or something too.For the 98 wrangler, mopar discontinued the radiator for the automatic. If anyone knows where to find one that would be amazing help.
All the sites I found said discontinued.Bought mine from the dealership a couple months ago. If you call one up they should have access to the distributor stock and get one in for you. Isn’t cheap but, thing is built like a tank. Could try one of the sites like Wermopar or something too.
What year, engine, etc?All the sites I found said discontinued.
The only difference is how the trans cooler lines plug in. You will need some tube adapters. A pair of these will plug into the new radiator and give you 3/8" barbs to attach your rubber lines to.For the 98 wrangler, mopar discontinued the radiator for the automatic. If anyone knows where to find one that would be amazing help.
Mopar discontinued the exact one for my 98 auto straight six and I haven't seen any floating around quite yet. Many of the other model radiators are still up just not mine in particular.Rockauto has one for about $250. Did I miss something?
It is only the exact model that direct fits with no extra adaptors or anything. Its the 52028123AB model. I can definitely use adaptors and all of that when the time comes but finding any of these exact ones would be a little better for reassurance more than anything.I just checked, did it sell out in the last few minutes?
If it helps, they are the exact same radiator. The only difference is how the lines hook up to the trans cooler part. The trans cooler lines are the same except for how they connect to the radiator. The only difference there is the short steel section connected to the rubber transmission hose.It is only the exact model that direct fits with no extra adaptors or anything. Its the 52028123AB model. I can definitely use adaptors and all of that when the time comes but finding any of these exact ones would be a little better for reassurance more than anything.
Great! Thanks for all the help.I have an 04, and part number 55037653AB which has 3/8 hose barbs. You can use that if you get clamps and cut your hose. I assume 5102983AA that rockauto lists for 1997-1999 wranglers has the quick connects that fit yours.
Post #9 says this guy was looking for the part you were and ordered what rockauto has and it worked.
wrangler forum . com /
f282/discontinued-parts-1470729.html
The only fix for a leaking water pump is its replacement.Update: there is now a steady drip from what i believe is the water pump. I am not totally sure where its coming from but I do need to stop it temporarily so I don’t poison any animals or pets.
There you go, spreading myths again. There are at least two methods to stop a leaking water pump. One is as you stated, replace it. The second is to drain all the coolant out of the radiator. No coolant, no leak.The only fix for a leaking water pump is its replacement.
Ah yes that works all right. From further inspection the leak is from the radiator hose on the pump’s clamp. It is hard to tell quite yet if it is yet. I have looked up some videos on how to get to the hose and water pump. It seems simple enough to get the fan and belt out but how hard is it to get that belt back in with proper tension and all?There you go, spreading myths again. There are at least two methods to stop a leaking water pump. One is as you stated, replace it. The second is to drain all the coolant out of the radiator. No coolant, no leak.
How does one re install this bolt to have the exact tension as it had before?Your 98's serpentine belt tension is controlled/adjusted by a very long vertical adjustment screw you'll find on the power steering pump bracket.
