Hi. First time post on the TJ forum, so, thanks for having me and sorry for the long post. I bought my 03 sport back in May and have been lurking here ever since. It is great to have this community as a resource. So, much thanks and much love, as always, to the Jeep community. Previously, I spent most of my time on the KJ forums but rarely posted there as most of the questions I have had, have been asked once or many times before.
I am soliciting some opinions here so any input would be much appreciated. I am having a bit of "well, while you're there…" syndrome in regards to some of the decisions I want to make.
My goal for my TJ is 'highly capable trail' more than rock crawler, I think. I already feel like my TJ is pretty capable. Extremely capable. (I even feel that way with the KJ). I love the TJ.
The TJ seems pretty stock. It has, what looks like, a cheaper, spacer based lift and is running 33's. The only things I have done to it are fluid changes all around and I replaced the LED headlights with some KC H4's. I also added a CB so I could talk to the group out on the trails.
My high level, short term (year or so), priority list is as follows:
Suspension later. And long term, I have been dreaming of a TDI or 2BT diesel swap. The 4.0l has 195k on it and has been very well taken care of from what I can see. There was one other owner and it looks like this TJ was towed most of it's life. I have an optimistic perception based on what I see that I can probably get another 100k out of this engine. The NV3550 was replaced at 150k, according to the previous owner and it does indeed look newer than the engine and NP231.
I have been hung up on sliders for a while. I have been wishy washy on drilling the body and realized that, because I am not really attacking boulder fields as much as narrow, tree lined trails, I can get away with the Quadratec QRC Rocker Guards, if for nothing else, to push and pivot around those trees.
The decision on the rocker guard/slider has allowed me to start planning the locker upgrade. Originally, I had put Dana 44 on my priority list to replace the Dana 30. I am not sure that is a priority anymore based on what I have read here and what I really want to do. Maybe one day, the TJ will see a Dana 60 front and back upgrade sometime after the diesel, but who knows. Anyway, after some very challenging but convincing trail rides here in the Washington and British Columbia cascades, combined with the aforementioned reading on this forum, I think the Dana 30 is a well enough platform for me to build up to support all future adventures.
So, my current drivetrain plan is:
For all this, plus some fluff, I have budgeted $5k. This includes the rocker guard mentioned above, all the fluids and a few new tools for the garage.
The list is this way so I can address a lot of "piece of mind," I suppose and was driven by, "well, since you've got that apart, you might as well replace…" thinking.
Which then puts me back, teetering on the idea of buying a crate axle to replace the Dana 30. Which I might be inclined to do if the major producers had Ox as an option. Out of all of the selectable lockers, I like the mechanical Ox locker the best. My perception is, with an e-locker, there could be gremlins. With the air locker, there could be an o-ring failure, air leak, compressor failure. With the Ox, it's a cable and I can get a drive-a-way lock. Don't get me wrong, I have read up on the locker failures here and think that the overall reliability is probably good enough but if all the apples and oranges are the same, my dime is on the cable. That's a lot of the reason I bought the TJ in the first place. (I will comment on the irony of these statements in the context of the 2BT later
My question to the group:
- Safety and recovery (this phase is done for now, minus the winch)
- Rock sliders
- Front locker
- Winch
- Front Locker
- Ox locker, manual, 30 spline
- 5.13 regear, ring and pinion. Looking at the Revolution regear Kit
- Front Chromoly 30 spline axle upgrade
- Ox sells the shafts also
- I am not convinced the CV axles are that much of a better option given, again my perception, the ability to trail fix a u-joint.
- Front unit bearing hub replacement
- Front and rear drive shaft u-joint replacement
- Front steering (Crown HD)
- Front knuckle ball joints
- Rear 5.13 regear
- I am planning on keeping the Tru-Trac for a while before putting an Ox locker in but will probably get to it before the end of 2020. At which time I will upgrade the rear shafts.
- Brake pad, rotor and caliper replacement
- What other, "since you've got that thing apart" maintenance, replacement, upgrades should I consider?
- Should I save up for a Dana 44 crate axle to put in the front? From what I have read, the answer is probably no.
- Should I invest in a truss for the front axle?
