Ok, so I've been having TPS codes pop non stop, even after installing a new Mopar TPS.
I figured for craps and giggles I'd change a few sensors out just incase one of the other sensors was giving a weird reading that some how triggered the TPS.
I removed the throttle body, cleaned it throughly, and replaced the idle speed control valve, the map sensor, the crankshaft position sensor, and the camshaft position sensor. I even removed the new TPS and cleaned out where it sits in the throttle body.
All parts are brand new Mopar parts from an authorized dealer using my vin number to make sure the parts are correct.
The battery was disconnected for several hours.
I connected the battery and turned the key and instantly it threw the P0340 code for the camshaft position sensor! And it was really hard to start. I removed the battery cables and replaced the new camshaft position sensor with the old one. The jeep fired right up with no codes, but now it's idling rough and I swear it is making a squeaking noise when the engine is idling.
WTH! I've seriously had it with this damn jeep!
Is there any way I screwed up the OPDA by removing the camshaft position sensor and reinstalling it?
