To all, I will be towing my TJ from Chicago to Ft. Worth in about a month, and will be using a tow dolly with the front wheels on the dolly. I think I want to just remove the rear drive shaft, but if I do, will the transfer case be open to the elements once I remove the shaft, meaning the sealed area will have some opening once i remove the shaft? I dont want any fluid to leak out or any road grime to fly up and potentially make it into the transfer case.
If I decide to not remove the rear drive shaft, do I just put the transfer case in neutral or does the transmission (automatic) also need to be in neutral? Thank you for any advice.
