Having read several threads on CB radio installs I totally understand the importance of having a good ground from the antenna mount. I'm going with the Teraflex taillight mount but have a problem as my Sahara has the tail light protectors installed and there is a layer of dense foam between the mount and the body.
So what is my best option for ensuring I get a good ground? If I clear the paint on the bracket from the upper mount bolt (where there is no foam) and body will that be enough of a ground through the bolt? If not, how could I run a ground strap? Any other suggestions from those that may have faced this issue?
