No ocd. At the end of the day you did not get the repair or quality that you bargained for.
So it's fairly normal practice to use bondo filler to cover the dimples and dings from hammering a panel out?
I'd have thought that youd have to get the body hammered out smooth....
I ask because I'm learning and find this whole body and paint subject interesting enough to maybe use some of my post GI bill to take a few tech school classes and learn about the process.
So on that topic, the radius by eye does look close but upon closer inspection you can tell that the radius decreases as you go from the untouched area to the area they did a repair. Only slightly but it is noticeable. I guess they said that the metal would only move so much without over stretching it. That's the explanation I got from the head manager trying to piece together this whole issue.Yes it is common to use filler to blend or shape imperfections. Filler becomes a problem when they use it too thick to cover up poor metal work. When used too thick it can crack and collect water among other things. It is hard to judge the repair from pictures, but they should have made a radius gauge to make sure the repaired corner matched the opposite side. Although the corner wont be perfect the difference should be undetectable by eye.
It may be temping to add corner protection but don't you have to drill holes into the sheet metal? It would seem to me that this would be a perfect area for corrosion to develop (in-between the sheet metal and corner protection plate).
Cutting and patching body panels also brings up problem of rust. If the body shop does not prep the seams and backsides, rust will shortly develop especially in any areas where welding was done.
As for the panel replacement I was gonna attempt it myself when i returned later next year.
The panels are fair cost from most online shops and the spot weld removal bits aren't too expensive. As for the metal prep and seam sealing, I was told about a paint that you can weld thru along with having a FSM for my wrangler showing the weld points along with the seam sealer locations and such.
Is this not a project you would recommend?
Not to beat a dead horse, but how far forward did they go with the new paint?These folks did spray from my tail gate to my passenger door where the rock guard is. That's the photo of the run in the paint where they joined the paint and clears.
I'm sure it's most certainly sand because the jeep still had a bit of sand in the fender liner when I picked it up. Lack of cleanliness and attention to detail.
But if this paint will hold strong till I ship out and return then I'll have more cash to get it done right. I'm willing to travel to someone who comes highly regarded and make it a little road trip when I'm on leave.
It sounds like a great start for some learning. I'm gonna practice on some junkyard panels before attacking the real deal.It is hard for me to recommend the panel replacement without knowing your skillset or tools situation. I would hate for you to make things worse. But maybe this is one of those situations where you need to do something to change the otherwise annoying repair. I say go for it and learn something new, but be prepared for some challenges.
What they are talking about is likely weld-thru primer. It is basically a primer with a conductive additive which is either zinc or copper. This allows the primer to be welded thru without totally destroying the protective coating of the primer. You will want to coat all surfaces where welding will occur especially between spot welded panels that you may not be able to coat after the fact.
Be patient with the spot weld cutter, if you push too hard you will go right thru both layers of metal. The idea is to cut away the weld from the top panel and cleanly separate it from the bottom with a sharp chisel.
Do you have a mig welder? You will want one that has shielding gas, flux core wire will work but its not as clean. Also get the thinnest welding wire you can, it will take less heat melt and you are less likely to burn through the metal. A specific resistance spot welder would be nice but its application is limited so the mig welder would be the more practical choice here.
Do not plan on your replacement panel being a perfect out-of-the-box fit. Most of these panels are made in China and they often need to be manipulated a bit. After tack welding the panel into position always assemble any affected parts to check overall fitment. In this case I would be most worried about the tail gate seal and gaps.
I can give you more suggestions for painting but how does the above sound?
They went as far as the passenger door seam and down to the strip between the passenger door and the rock guard which is where the run is.Not to beat a dead horse, but how far forward did they go with the new paint?
I agree with you. in that the lack of cleanliness and detail was lacking. It's extra steps to take, in this case, but there's ways to prevent or minimize trash from getting in the paint. Pressure washing, masking areas off, wetting the floor, and probably others that I'm unaware of. They just chose not to take the time.
Surely it'll hang in just fine until you return. If you do still plan to take it on once you get back, it'll be cool to see your progress. There's a guy on YouTube that does paintless dent repair. The results are pretty mind blowing with some of the jobs he takes on. I forget the name of his channel, but "paintless dent repair" will probably get you to it pretty quickly.
