How to remove center console
Moab
TJ Expert
Bohol, Phillipines/El Segundo, California
Couldn't find a "how to" on here for removing the center console. Found this great 8 step picture tutorial on Jeep Guide.
Probably could have figured this out on my own. But so much safer having a tutorial to follow. Plus I had no idea how the shift handle was removed.
Removing A Wrangler (TJ) Center Floor Console
The following images document the removal of the center floor console of a 2000 Jeep Wrangler TJ Automatic.
STEP 1
We started by removing the first screw, located in the front cup holder.
STEP 2
We then removed two screws located in the center console storage compartment.
STEP 3
Then we removed the screws at the based of the center console. We slid/collapsed the front seats forward to access them.
STEP 4
We then pried out the display of the automatic shifter with a flat screw driver.
STEP 5
We also popped out the airbag panel that sits in front of the automatic shifter.
STEP 6
Before we removed the center console, we put engaed the e-brake, put the transmission in 4-low, and removed the automatic shifter handle. This helped with being up to simply pull up on the console assembly and slide it up and out of the area.
The shifter T-handle is shown still attached in this picture. To remove it, we simply pulled up very hard and it popped off. If we left the shifter T-handle on, it's possible to remove the console, but it takes time to get the angles correct. We re-installed the shfiter T-handle by placing it on the shifter stem and pressing down.
STEP 7
This image shows the center console removed.
STEP 8
Closer picture of the transmission and transfer case controls.
Really the only thing holding me back was the removal of the shift handle. lol. Who knew it was so easy? I read your post on that first. As it was the only one I could find. Then I found that tutorial.
Hoping to start on my sound deadening this week. Thus the need to remove the center console. Think I'm gonna break it down front and then back. Do it over a couple or few days. But after I remove everything I'm going to temporarily lay down my new ACC carpet to mark it's coverage. So I can put down as much sound deadener as possible. Then heat shield over that. The ACC is supposed to be oversized. So I'm hoping that all fits under the carpet. I'll know once I temporarily lay down the new carpet. Hopefully it will all fit under it. The only complaints I've heard about the ACC is you have to trim it yourself. Which is a good thing for me. Hopefully it's plenty extended along the sides. For extra room.
Old thread I know. Is this completely the same for a manual transmission?
Thanks
Thanks
Nope, easier. Remove that cup holder screw, pop off the stick cover which should be metal clips on the four corners, remove screw for that front console part, the end. I just played with the console on my '05.
Reactions: Sancho
