Yesterday I changed the oil in my 2000 TJ (4.0 engine) for the first time since I purchased it from a local dealership. When I brought it home back in August, I noticed that the oil was overfilled quite a bit, so I drained some until I read the appropriate level on the dipstick. At that time, I also noted that the oil drain plug needed some help, so I purchased a replacement on Rockauto in order to have it on hand when the time came to actually change the oil.
Well, yesterday after draining the oil, I discovered that the 1/2-20 drain plug I had bought was too small. I checked Rockauto again, and noted that all of the plugs they sold for my year and model are 1/2-20... so I took the drain plug I had removed to Auto Zone and purchased one that was the correct size for the oil pan I'd taken it out of (M14-1.50).
At this point, it seems pretty clear that I don't have the stock oil pan, given that the drain plug is a different size and that the dealership overfilled it (probably expecting a 6 quart capacity). I put 5 quarts in, which came up right to the middle of the "SAFE" area of the dipstick. To the best of my knowledge, I've got a 4.0 engine (I've got the decals and VIN for one, anyway).
The question is... should I leave the oil pan alone, or replace it with a factory one?
Here's the top view of the engine... looks like a 4.0 to me (but I'm pretty new at the Jeep game):
