Instrument Gauges Not Working
Jay MacLeay
Los Angeles, CA, United States
I recently replaced the heater core in my 2005 tj rubicon. Now my instrument Gauges don't work. The backlight on the cluster works and the odometer reading works, until I start the Jeep then it goes out and doesn't return for a short period of time after the Jeep is turned off. Is there something I forgot to reconnect?
Thanks, but I have to admit that I am an idiot... After posting this I checked the #10 fuse location in the fuse panel behind the glove box. I must have removed it and not replaced it. New fuse. Problem solved.
I once spent 2 days trying to figure out why the engine on my wife's Lexus wouldn't fire up after I replaced it only to find out that I didn't connect the main engine ground cable on the back of the intake manifold. I must have looked at that dangling cable a dozen times.
hey jay i say your post and cam gear wear.
Looking for tips on how to replace camshaft
couldnt figure out how to send you a private message. did you ever get it fixed? new cam, opda, engine?
