Stupid neophyte questions
I'm not going to say this for certain - but there's a "speed sensor" on the TC with a cable that plugs into it...
Ok, you can call it a "speed sensor" of sorts if you like, and it does have an electrical connection that feeds data to the ECM, but you still have to change the gear to a different toothed gear to calibrate the speedo after a tire size change.
If you unbolt the clamp to the sensor on the t-case, you will then be able to pull it out and you will see a plastic gear,
https://www.quadratec.com/c/reference/jeep-speedometer-gear-tooth-chart
That is where the handy little chart comes into play.
Reactions: Zorba
Ok, I'll have to wait until tomorrow at the very least to take a picture - its getting dark and its supposed to rain, blah, blah...
EDIT: Never mind, bobthetj03's picture is exactly what I'm referring to. Obviously he knows!
