I'm setting up new 4.88 gears in my Dana 44 with my ARB. I could use some input on interpreting these patterns
This was the first pattern I pulled and didn't write down the specs, it was at 42 thou pinion depth and maybe 7-8 backlash
The numbers below indicate inner pinion shim/outer shim/RGS shim/NRGS shim and B/L that I've been using for reference
53 seems too deep but I'm struggling to interpret what 49 and 50 show. I'm trying my best to get the carrier loaded when checking the pattern. The axle is on my bench so it's been tough. I've been using a small piece of wood between the carrier and a pry bar. Any tips would be appreciated!
