Want to see what you guys think are a good upgrade/replacement for the stock beams with another sealed beam setup.
Thanks!
Thanks!
Came across this video a while back, it's very helpful and informativeWant to see what you guys think are a good upgrade/replacement for the stock beams with another sealed beam setup.
Thanks!
I watched part of it in the headlight thread, I didn't think they covered sealed beams?Came across this video a while back, it's very helpful and informative
Upgrade and sealed beam, I don't know about that one. If you want to keep glass then you might consider some nice H4 housings.
As for H4 housings; there are so many to choose from. Hella, PIAA, IPF, KC, & Kyoto (sp?)
IF you choose to go that route; make sure to install a dedicated electrical harness instead of using the 18 ga factory wiring to power the H4 bulbs.
In my past two Jeeps I installed Hella and IPF H4 housings since they wee the easiest to find at the time.
I was afraid you were going to say that.That's a bit of a misnomer if you ask me.
I was hoping for something relatively inexpensive and plug & play rather than needing an entire harness.
Anything this side of candles is an upgrade from the OEM garbage.
So what you're saying is that the wiring is inadequate for even the factory sealed beams?There are a few reasons why I recommend the harness.
If you were to check the voltage at the factory headlight connectors; you might be surprised to find only 11.3-11.6V.
The 18 gauge factory headlight wiring will only support about 7.5A.
No matter what headlights you install whether they are sealed or H4 housings; they will not provide much of a headlight upgrade with voltage and wiring like that.
Nothing else for the ones you linked.I think these are what my dad was talking about.
https://shop.advanceautoparts.com/p...4stbx/5080065-P?searchTerm=headlight assembly
So, if I'm going to change these old ones out and get them to work safely, what would I also need in addition to the lights to make it work?
