Here's a list of the different fluid capacities for various Wrangler TJ models.
Engine
2.5L 4 cyl - 4 quarts
2.4L 4 cyl - 5 quarts
4.0L 6 cyl - 6 quarts
Transmission
30RH 3 speed auto
ATF+4 is replacement). See post #2 below for fluid amount. Make sure to use ATF+4, not just ATF!
32RH 3 speed auto
Approximately 4 quarts ATF+4 is replacement) when drained via dropping the pan / Approximately 8 quarts dry fill. See post #2 below for FSM procedure. Make sure to use ATF+4, not just ATF!
42RLE 4 speed auto
Approximately 4 quarts ATF+4 when drained via dropping the pan / Approximately 8.8 quarts dry fill. Make sure to use ATF+4, not just ATF!
AX-5 5 speed manual
3.3 quarts 75W-90 GL4, or 10W30 (NOT GL5 or GL5 compatible as incorrectly stated in some of the manuals). I highly recommend Redline MT-90.
AX-15 5 speed manual
3.32 quarts 75W-90 GL4, or 10W30 (NOT GL5 or GL5 compatible as incorrectly stated in some of the manuals). I highly recommend Redline MT-90.
NV3550 5 speed manual
2.1 quarts. I highly recommend Redline MTL.
NV1500 5 speed manual
2.4 quarts. I highly recommend Redline MTL.
NSG370 6 speed manual
1.58 quarts. I highly recommend Redline MTL.
Transfer Case
231
1.1 quarts ATF+3 or ATF+4
241
2.1 quarts ATF+4
NOTE: The 231 and 241 transfer cases are fine with any type of good quality ATF. Mercon, Dexron, ATF+4, etc. are all fine. Only the automatic transmission is fussy about the type of ATF it gets.
Axles
Dana 30 - 1.25 quarts 75W-140 (1997 model takes 1.65 quarts)
Dana 35 - 1.75 quarts 75W-140 *
Dana 44 - 2 quarts 75W-140 *
Rubicon Dana 44 (front) - 1.375 quarts 75W-140 synthetic
Rubicon Dana 44 (rear) - 2 quarts 75W-140 synthetic **
* 4 oz of friction modifier is required with Trac-Lok limited slip differential.
** Friction modifier is NOT required with Tru-Lok locker/limited slip differential (factory Rubicon locker).
Cooling System
The Jeep Wrangler TJ came with a HOAT coolant from the factory. I always recommend running OE Mopar coolant or Zerex G-05, which are both HOAT coolants.
2.5L - 9 quarts
2.4L - 10.1 quarts
4.0L - 10.5 quarts
Engine
Transmission
30RH 3 speed auto
32RH 3 speed auto
42RLE 4 speed auto
AX-5 5 speed manual
Transfer Case
231
241
2.1 quarts ATF+4
Axles
Cooling System
2.5L - 9 quarts
2.4L - 10.1 quarts
4.0L - 10.5 quarts
