That or the intake for the locker pumps.Is that not the hose to engage the locker?
You don’t need to replace the entire hose unless it’s lost it’s pliability. Just purchase a 5/16” vacuum connector and enough hose to run it up by the filler hose. You’ll also need a breather to keep debris out. Something like this:Just looked and it is coming from the compressor. I stuck my thumb over the end of the hose and used a broom handle to toggle the switch and if and sure enough its the compressor intake! still cant find the other end though. Should I replace the whole line? Does it run into the same place as the diff vent?
