I've had my 2002 manual TJ for 4 years now. It has always had this rubbing whirring sound coming from the transmission or gear box area. It occurs when I let off the gas. The noise slightly decreases when I engage the clutch. I've had all gear oils and transmission oils replaced. My clutch works fine. Do you think it is throw out bearing? I've read one post that say to put in heavier oils. Other posts seem to say this is normal. I believe the previous owner towed the jeep behind an RV as it has the tow bar attachments on the bumber and my jeep had only 80k miles on it when purchased. Help on this matter will be greatly appreciated! Thanks
