Meaning that the tires and axle are being yanked off the ground?
Yes on rebound. Or at least it could feel that way.
They might not get airborne, but at the end of the shock travel, there is a sudden 400-500lb anchor pulling at the body/frame rather than a smooth transition of movements.Yes on rebound. Or at least it could feel that way.
If I got the truck but never plan on actually hauling anything I would get shocks that were meant for the unloaded weight only and with a travel bias that matched the ride height unloaded. I would not change ride height or springs. Of course I use my truck and just accept the ride as it is unloaded in reality.Absolutely. So what is the solution?
1) You always carry a load in your pickup.
2) You replace or tune the shocks in your pickup.
3) You replace the springs (and shocks) in your pickup.
Realistically you purchased the truck to haul stuff, so answer #1 would be the solution. But lets say you just got a great deal on the truck so you purchased this truck instead of a lighter truck and you never plan to haul anything. What is the solution? I would say the solution is #3. You replace the springs and install the appropriate shocks. Its a system that works together. You can't tune away the wrong springs. Even with a good shock tune.
EDIT: Well maybe you could with the right guy doing the tuning. But it doesn't seem like the proper solution to me. What is your solution?
... I would get shocks that were meant for the unloaded weight only and with a travel bias that matched the ride height unloaded. I would not change ride height or springs....
Without a load, the shock and spring move the chassis upward fairly easily. When that happens, it tries to yank the rear axle off the ground and the rear end skitters across the road and the ride is very jarring.Hitting a bump the axle would swing up closer to the frame and compress the shock. Upon rebound the shock could over extend creating a jarring experience.
Hitting a hole, the axle would drop away from the frame, possibly over extending the shock as well.
Trying to be anyway.Meaning that the tires and axle are being yanked off the ground?
Not on rebound, full extension.Yes on rebound. Or at least it could feel that way.
The only solution is you put up with a shit ride quality when you are not using the truck within its design parameters which are to carry relatively large loads. You have the exact same scenario.Absolutely. So what is the solution?
I use mine as well for its intended purpose.If I got the truck but never plan on actually hauling anything I would get shocks that were meant for the unloaded weight only and with a travel bias that matched the ride height unloaded. I would not change ride height or springs. Of course I use my truck and just accept the ride as it is unloaded in reality.
Who does outboard work on a 3" lift?OK, let me put forth a different scenario using Jeeps.
Some guy comes into your shop with a 4cyl TJ with a soft top sitting on an OME ZJ/LJ combo, because he read on the internet OME is the best and the ZJ/LJ springs will give him 3+" of lift. Now he says his OME Sport shocks ride terrible and he wants you to put on some custom tuned Fox shocks so he can get a great ride. He loves the height he has with the ZJ/LJ combo and he has the long OME shocks. So shock bias should be pretty close to where it needs to be. The rest of his setup all looks pretty good.
Do you set him up with new shocks that are properly tuned to the ZJ/LJ setup on a 4cyl or does that Jeep need softer coils? I don't mean to be offensive here. I really want to know if a good shock tune can really overcome that stiff of a spring on a 4 cyl TJ. Are springs really that irrelevant?
I can get shocks any travel I want within reason. The point is very few folks will pay or invest roughly 3 grand for a lift height most know will not be there for the long term and when they get to where they want to run 35's, they will pay to do it all again.OK, you got me. (I figured there be something I missed) What doesn't work here. Shocks too long without outboarding them?
Dave is open to the public and has to take their money. I am not and don't. He also outboards shit shocks and I won't do that.Pretty sure @David Kishpaugh does
All good points.Dave is open to the public and has to take their money. I am not and don't. He also outboards shit shocks and I won't do that.
