I am kind of working in the dark because I don't have any examples of how others have been mounted at the axle.
PSC's written guidance, was that the heims should be mounted parallel to the axle. That seemed to rule out using the stock/existing stabilizer mount. I have seen pictures of track bar mounts that have been broken and/or holes wallowed. I also thought that the ram would need to be mounted forward of the axle housing to create enough clearance. Cutting and welding is not a problem in my circumstances.
So, my thought was that I'd want or need a new bracket that was stronger than stock and that had a mounting point for the ram. I'd never heard of a bracket like that which seemed off to me because I've read quite a few threads/posts. (The reason for my original post.)
I planned to connect the other end of the ram to the tie-rod aspect of the Currie Currectlync (as opposed to the drag link) with this bracket:
PSC Steering TRCL08B Tie Rod Clamp
I would appreciate your guidance on the most effective ways to mount the ram on a TJ.
