wow, I am shocked by this! what is the reason for this? Surely the theft rate can't be higher than places like Newark NJ?I'm sure insurance prices are crazy in NY, like everything there... But you can't compete with state averages:
So, my thoughts are I can probably save this thing, find a creative way to tweak the front RH rail closer to straight, then bolt on some new (salvage) sheet metal. Crazy?
Three of my cars, my ATV’s and my trailer are fully insured for less than that New York number combined.I'm sure insurance prices are crazy in NY, like everything there... But you can't compete with state averages:
I wanted to follow up with what I've learned about frame damage. The frame/body shop I took it to just put it on an alignment rack, saw the thrust angle issues (from bent axle brackets and track bars), rust at the body mounts and all of the other damage and decided they didn't want to work on it. They suspected a bent frame, but took no measurements and couldn't point to any frame damage. I don't fault them, they knew a repair to factory specs would cost much more than the Jeep's value.
So, not willing to write it off yet, I took some shade-tree frame measurements on my garage floor. I made a plumb bob out of a banjo bolt, grommet, magnetic washer and some monofilament, set up the frame center rail sections parallel to my floor on jack stands and made a chalk layout on the floor. The results were better than I feared - everything rear of the front arm mounts looks perfectly straight, the diagonal measurements were spot-on. The front measurements were taken just behind the bumper for height and from slots on the bottom of the rail about 13" rear of the bumper for lateral. The RH rail is 14 mm low at the bumper and 20 mm outboard at the slot.View attachment 183835
View attachment 183837 View attachment 183838
Sounds like you've got a lot of experience with this, wish Omaha was closer... If I put an anchor in my garage floor to hold the frame down, what are the chances I'll just crack and pull up the concrete?I would pick a point on the left side behind the spring mount and measure xyz coordinates from it. Find a point on the right side at the exact same location so you have a good starting point. You may need to start from the transmission skid plate.
Otherwise the right could be 1-2mm off further back then you think. Sraighten from where they match forward. Use the front edge as your lever arm since it's longest, but determine the pull angles from xyz measurements. Change zero point and get a new xyz measurement and pull angle after each adjustment.
Or pull on it with something on the front corner and go to town with a 10 lb sledge and torch until "close enough".
I've done both ways depending on who's paying for it.
Thanks for the offer WNC05willys, I may take you up on it. My parents are in Waynesville, so I get down that way occasionally.just found this thread....Wow!! So glad everyone is unhurt, my youngest is coming up on driving age and cant wait to get my tj wheels dirty. I have a few takeoffs I'm happy to donate, with more stuff coming. PM me if you need a list, its not much but you are welcome to anything I have
