The Jeep was difficult to start due to a leaking check valve in the fuel pump. It would also not start at all after a 10-20 mile trip when it was hot outside. After it cooled for 30 or so min it would then start with a few cranks of the key. I then tried installing design engineering’s fuel rail and injectors insulator kit. Made no noticeable difference
I then replaced the fuel pump and the Jeep starts very well now. But I took it for a 20 mile trip last week when it was hot outside. Once I parked it, I tried starting it about 5 min later. Same thing, would crank and everything would sound good except it wouldn’t fire. My thoughts are the heat from the motor after a longer trip cooks the fuel in the fuel rail to a vapor and vapor locks.
So today I barrowed a fuel tester and on key cycle, the pressure shoots up to about 47lbs and then will lose about 1lb of pressure per minute for the first few minutes and then hold at about 38lbs. I stopped the testing after 15 minutes
Sound like normal fuel pressure loss or do I have leaky injectors?
