I got tired of move around the garage the onboard air system parts that should go on the Sport 98 and decide to put it on the Unlimited, originally Sport 98 was going to have the A/C compressor converted to an air compressor, now I will get an electric pump as the Unlimited A/C still on good shape.
I do have an 2.5 gallons tank mounted on the bottom rear of the jeep and was thinking on get the ARB CKMA12 air pump to complete the system. The same is 50% Duty cycle and 2.18/2.65 CFM, I'm under the impression that this will work fine with the tank as the primary use will be air up my 33" tires. ARB lockers on mind as well, that's why I'm going to this pain
I do have very little experience with this type of air pumps and onboard system. Like to heard if any one have a look like set up and/or use this pump as well.
Edit:
It's other brands like VIAIR and PUMA that may be better for this application that I'm open to heard about as well.
Seeking your appreciated advice.
Edit:
