My son bought a 2006 Grand Cherokee. It has a 1" lift with new coils, struts and shocks. The previous owner stated the lift was just "blocks". I assume that means a body lift? How much trouble is it to remove the lift? Does that also entail replacing the coils, struts and shocks? If it does require replacing those items what are the best stock replacement parts? Should we go with Rancho shocks like a TJ? Our local mechanic (not a 4x4 or Jeep guy) said it would cost about $400-$500 replace all this. I'm unsure if all these parts need replacing with only a 1" lift.
As you can see it looks a little goofy with the lift and stock tires and wheels. (Even more goofy on flat ground.) We don't need the lift. And I think it will ride better without it. It's a limited with 118k and quadratec 4 wheel drive. It was a tow behind on an RV though. It's a tiny bit bouncy in the ass end. And makes a kind of spring squeaky noise when you go over large bumps. I'm hoping getting rid of the lift and going back to a stock configuration will solve that. Don't want to spend a ton of money doing it. But if there are parts like the Rancho shocks that will make it ride even better. I'm all ears.
