With more experience you'd learn there are WAY more downs than ups to to running 35's with a 2" lift. And personally, I can't come up with a single 'up' to that combination other than more $$$ in the bank from not having spent the $$$ to do it right.With all due respect Chris as I really value your experience and expertise but when you lift it aren't you also making sacrifices? I've seen jeeps flop on their side on things I've walked through. I've also been hung up on my belly where lifted jeeps walk through. I believe both sides of the spectrum have ups and downs
You may have convinced yourself doing that to achieve a lower COG is a good thing but it's just going to suck at everything. But of course you're right and we're all wrong in your mind so just go do it. And though I know I'm just shouting into the wind here, lifting a TJ enough to successfully run 35's doesn't mean its COG will be high enough to cause it to flop.
Here's just one example, and no the photo has not been edited to make it look like he's tipped further over than he really is. This is a Jeep that mrblaine built years ago.
The bottom line is installing the RECOMMENDED 4" suspension lift plus a 1" body lift for 35's is not going to be causing your Jeep to flop or roll on a trail you're likely to run unless you do something really dumb. You have the same fear that any relatively new or unexperienced offroader has about installing too much lift height but trust us when we say it's not the issue you're thinking it is. Not by a long shot.
You can't run 35's and expect your Jeep to perform, stop, and handle well without a lot of work and $$$. If you're not going to do it right, don't do it at all.
