Yeah the bolt pattern in the title is specific so I started a new threadboth my YJ and my TJ only run the stock 5 on 4.5 lug pattern
Yes they are, some of us did axle modifications that converted the bolt pattern to 5x5.5".both my YJ and my TJ only run the stock 5 on 4.5 lug pattern
and I'm jealous of those of you who have beefed up their axles...someday I'll get thereYes they are, some of us did axle modifications that converted the bolt pattern to 5x5.5".
Dude that thing is so bad a$$.
I'm a fan of contrasting black nuts
What did you do to the front to make it happen? I’ve been shopping rims for Black Friday and hate the idea of spacers, but JK rims are so much cheaper and common.Yes they are, some of us did axle modifications that converted the bolt pattern to 5x5.5".
A Warn big hub conversion kit with 30 spline shafts. Yukon bought that business from Warn later.What did you do to the front to make it happen?
That’s a mistake on my part I was thinking it was a 5x5 the warm kit takes you up to a 5x5.5 right?A Warn big hub conversion kit with 30 spline shafts. Yukon bought that business from Warn later.
Yes.That’s a mistake on my part I was thinking it was a 5x5 the warm kit takes you up to a 5x5.5 right?
Forged aluminum is even lighter and stronger.Sweet those look good on there. When and if I ever decide to put my TJ on a diet and get some aluminum wheels Raceline is one option.
I really like the looks of those stazworks wheels. They are enough different than the typical 8 slot d hole steelie, but they still have the classic look. Big fan.9x16.5 with a 5 on 5.5" lug pattern. Custom made STEEL dual beadlock rims from StazWorks .
I was able to see just how tough his rims are while deployed to Iraq. A F550 gun truck hit and IED and it mangled that truck pretty good but other than gouging the powder coat the rims were fine.
Here is a thread I did this past summer.
Stazworks Dual Beadlock Wheels | Jeep Wrangler TJ Forum
And before these rims I had some recentered Hummv rims that over time broke on me.
Allied beadlocks
