I did if I cycle the key off and back on it will startyou tired the cycle the ignition check? ... if it still doesn't work when you do that, you can check your fuel rail pressure when warm (carefuling). or drop the tank and pull the pump and check it, but at that point, your 1/2 tempted to just replace it anyway cause you already have it out.
