So I have a 2000 Jeep with the 4L I6 with 104000 miles on it. I'm currently having a rough idling issue. I took it in to a local shop to see what the issue was because my jeep would stall out in reverse or whenever stopped. They told me that it was the TPS (P1294) and all that needed to be done was to reteach the sensor. After that, I was idling around 700 RPMs and saw that the idle would fluctuate. The other day I was driving to work and my jeep's RPMs dropped all of a sudden and then it stalled. I took it back into the shop and they told me that the thermostat that was in my jeep was not the correct one (they could only get it up to 170). The code they got was for the engine not getting up to temp (P1281) and that my TPS voltage was high (P0123). They also found that my clock spring is bad and that there might be a short. Now when I cold start my jeep, it starts at around 900 RPMs, but as soon as the engine starts to warm up it goes down to around 600 RPMs and drops down to around 300RPMs when I stop.
I'm planning on replacing my TPS and clock spring.
Any ideas of what might be the problem?
