B00mb00m
The Church of Cutting Brakes of Atlas-Front Digs
I had some maintenance stuff to do and wanted to check the yoke nuts on my transfer case. When I disconnected the front driveshaft I was unable to compress the driveshaft. I used a piece of aluminum and a dead blow and was able to get the two half's disconnected (marked spline tooth for alignment) and it was dry ish but not corroded. I regreased with some good moly grease but it's still quite tight at the bottom of the shaft, which is the area typically exposed to the elements.
Nothing looks bent or damaged. Is this anything to be concerned about?
