Recently did a heater core swap, now I have no heat.
on the disassembly I broke a blend door. The horizontal one to be precise. 2003 with A/C.
I played with the actuator to see if I could fix it. Drilled a hole in the arm and used a zip tie to attach said arm to actuator.
so now I have no heat. Which where I live makes the vehicle undriveable.
Where should I go from here?
