Now that was just mean. The guy had COVID!Smell the fluid... you’ll know what it is then
Brake fluid will be clear, gear oil will be, well, oil colored...I didn’t check the brake fluid but I will. With as much fluid as looks like has leaked out, if it was brake fluid I doubt I could stop!! Thx folks.
Best comment of the month. Thanks for the laugh.Now that was just mean. The guy had COVID!
Well hell. Now the other side of the rear axle is leaking. WTF??!!! Based on the other side already being replaced twice, what’s y’all’s prognosis??
Yeah I’m sure it’s the seal. But with both leaking within a few months of each other...coincidence or signs of other troubles?Axle seal, don’t get the replacement from Amazon.
I’d expect similar life from each, so if they’ve never been touched before then it could make sense. I didn’t read the whole thread but did you make sure your axle breather isn’t clogged?Yeah I’m sure it’s the seal. But with both leaking within a few months of each other...coincidence or signs of other troubles?
I haven’t. But I would think the shop I took it to previous would have done that. And not sure I would know how to check it other than just visually?? Yeah, I’m real new to this.I’d expect similar life from each, so if they’ve never been touched before then it could make sense. I didn’t read the whole thread but did you make sure your axle breather isn’t clogged?
