Replacement Exhaust Manifold
Rescue6
Colorado
Looking for a replacement exhaust manifold for a 1999. Just wondering if there are any that people have had good fb luck with. They seem to range from about $60-$275 for the stock type replacement with the flex joints added. Anyone used one that’s held up without cracking. This will be my fourth exhaust manifold or header to install because everything I’ve tried so far has wound up cracked. Thanks for the help.
My current Dorman is the 4th for me as well. I installed it last Feb, and so far it's ok. It's the first one with the flex joints for me. Has about 10k miles on it, give or take a few hunge.
This will be the first one with the flex joints for me as well. I lm hoping it lasts better that the expensive headers I’ve been using.
The crown one I used had the flex joints on it. I also painted it with a paint from Eastwood for exhaust..
My Daughter said it still looks good. The paint I used you spray on and let dry then it cures after its heated up b the engine.
Reactions: Rescue6
