Error Code P0420 on 2000 TJ
AaronPaul
Washington DC
Does anyone know which of the 4 O2 sensors this code is meant for? My check engine light is on and this is the code. Can anyone help?
Thank you
How many miles are on your Jeep? It sounds like your cats could be failing.
I have no loss of power, do not smell rotten eggs. The Jeep has 48k on it currently.
The code came up as P0420 CAT 1
48k
no loss of power, no smell at all and I don’t think I have any leaks
Disconnect your battery and clear the code it might not come back if its running ok.
I got both up and down stream o2 codes 6 months ago just after buying it and they have not come back.
Thank you. I will try that but I want to make sure everything is running ok as well.
Are you saying the Cat is bad?
It could be a bad catalytic converter. The way it works is that you have an O2 sensor in front of the cat and an O2 sensor behind the cat. The computer compares signals between the two to make sure the cat is cleaning up the exhaust like it should. If it doesn't see enough of a difference between the two sensors it raises that P0420 code.
Thank you for the info. So what are my options? I know where the sensors are I just don't know which one to replace. There are 4 sensors correct?
The Post 02 is only there to tell you your cats not functioning properly. Cheap enough from Rockauto but make sure they are NTK
I got told a trade secret by my home A/C repairer, When the A/C stops working unplug it or switch it off at the power source for 10 mins and then switch it back on, saved me a small fortune over the years :)
Bank 1 is the front catalyst off cylinders 1-3. You have a bank 1 sensor 1(pre cat) and bank 1 sensor 2(post cat). You have the same for bank 2 which is off the rear 3 cylinders. In my experience p0420/430 usually are not bad o2 sensors but you can certainly try to change them if you like.
