I am looking for your help with direction I should take my 2003 Wrangler X.
I do not plan to do any wild off-roading or rock crawling, but would like to go off-road and explore fire roads, mountain trails with some confidence of not breaking anything if I hit some rough areas. For the most part this is a "street jeep".
Currently equipped with: 4.0 6 Cyl., Automatic, 118k miles, 2.5 inch Rough Country suspension lift and front stabilizer bar, 16 inch Rubicon Wheels with BF Goodrich All Terains, Besttop Highrock bumpers front and rear, Smitty bilt X2O 10,000 winch, Hella 500 driving lamps. Dana 35 rear - no posi or limited slip.
I have read alot about doing the Super 35 swap versus going through the trouble and expense of the dana 44 swap, so I have several questions around that:
- I thought it would make sense to just get a limited slip rear because I am assuming with an open rear I really only have a "3-wheel drive" jeep? LOL!
- Or, is this what I should get - The Super 35 shaft kit and an Eaton 30 spline E-locker for Dana 35.
- If I change the rear do I also need to change the front axle to match?
- I am assuming 3:73 Gears? Is there a way to confirm this?
- And do I want to change the gearing? If yes, do I need to change both front & rear?
- I do not intend to put any tires above 33 inch on it
I appreciate the help!
Nivek
Nivek
